Hi Titus,
You would also need a GND connection for the Step/Dir signals to work.
Your configuration seems correct.
I think the G540 has some inputs for estop and charge pump to be enabled. Check the Gecko manual. You can tell if the drive is enabled by checking if the motors have holding torque.
KFLOP loses its configuration whenever power is lost unless the memory is FLASHED. But we don't recommend you to FLASH anything to the
to KFLOP. The PC can easily configure KFLOP on Initialization or Reset. You might watch this video:
http://dynomotion.com/Help/FlashHelp/Parameters/index.html
The "Move" button should make a move at the selected Size, Velocity, Acceleration, and Jerk. Units are
Microsteps and seconds. "Step: has no useful purpose for a Stepper Motor.
Message: 8803 |
Date: 12/17/2013 |
| Subject: Re: Need help getting going |
Hi Titus,
HTH Regards TK
Message: 8804 |
Date: 12/17/2013 |
Thanks for the fast reply.
I connected DB25 pin 18 => JP7 pin 25 and DB25 pin 19 to JP7 pin 26 for the GND connections which I'm assuming should cover my bases.
The chargepump/estop I had already disabled on the G540 so I knew that wasn't the problem.
I went back to basics and started testing the continuity of the cable I was using and sure enough -- the cable pinout wasn't how I thought it was labeled and thus the correct pins were not mapping as they should have been.
I tossed the cable and used some one-pin arduino style connectors to temporarily make all the connections. I'm very happy to say it's working now.
I'll definitely watch the video you mentioned when I have more time later tonight.
Thanks for your help!
